winnie
- Springfield, MA, USA
- Electric motor research
We discussed this video clip before, and I did some calculations. See post 18 in this thread http://forums.mikeholt.com/showthread.php?t=86536
While capacitors are generally two terminal devices, you can assign a capacitance value to a single electrode, by assuming that the other electrode is the 'rest of the universe at infinity'. The capacitance of a sphere (relative to the rest of the universe) is a well known equation, and a pretty good approximation to the capacitance of a sphere some distance from the earth.
I estimated that the helicopter would form a 330pf capacitor to the earth.
Okay, take a 500kV 60Hz source, and connect one terminal to earth, and the other terminal to a sphere big enough to form a 330pf capacitor. About 60mA will flow through this circuit.
When the helicopter is bonded to the line, something like 60mA is flowing through the bond wire. It might be 6mA, or it might be 600mA; this was not a particularly accurate estimate. But the current flowing between the line and the helicopter, charging and discharging that capacitor will be significant. Prior to connecting the bonding wire (or after disconnecting it), any arc that forms will carry nearly that same charging current. I know from experience that a 20mA 60Hz arc is quite noticeable!
I would like to note that in the circuit that I am describing, the arcing is _not_ caused by the capacitance between the line and the helicopter. Capacitive current flow does not entail electrons flowing between the capacitor electrodes. Instead electrons flow into
(or out of) the electrodes, causing an electric field between the electrodes. The capacitive current flow between line and ground does not cause an arc. Similarly the capacitive current flow between line and helicopter would not cause any arcing. But we have a series circuit; the capacitance from line to helicopter and the capacitance from helicopter to ground. When the helicopter is close to the lines, the line-helicopter capacitor breaks down, arcing over to supply the current flowing through the helicopter-ground capacitance.
-Jon
-Jon
