kwired
Electron manager
- NE Nebraska
- EC
does the POCO offer services at their distribution voltage level? That is probably the first major question. If they do what other requirements may go along with providing service at those voltage levels? Many cases you are looking at 12.47/7.2 kV. Not something you want someone working on without very good understanding of how to install/operate/maintain such a system. Under 600 volts is bad enough to have people that don't fully understand but they can get away with things you just can't at medium and high voltages.However this policy on the part of the POCO runs contrary to the fact that they literally prohibit the customer from buying his own transformer and state that they do not want it that way. A customer can buy a remanufactured trafo for less than half of what POCO wants. And forget about the lifetime maintenance story since the customer has absolutely no problem assuming that risk. He says he can save $15,000 on a top class oil filled copper wound trafo if he buys his own, plus he would own it. This does seem somewhat unfair, even unamerican. If you were a customer would you be happy??
If you do have well qualified people to operate and maintain this equipment they are not going to do it for $15 an hour either, but you very well might have some earning that wage that do work on low voltage equipment. Though I can talk a lot about medium and high voltage, I will not actually work on them because I have no experience, and don't need the liability either if I don't get some training so I understand how to work with them at a much higher level then what I do know. I would imagine most any POCO that has good concerns for protecting life and property would want to see some requirements be met before they would be willing to supply a customer with medium voltage service. How that works out legally I don't know, but I can see it lessening their liability also over just bringing in a 12,470/7200 line and saying "it's all yours from this point on".
