Cutting Plaster on Wood Lath
Article 90.1
The vacuum attachment for the rotozip works well. Add some blue painters tape to the base plate to reduce any marring of the walls, just like you would on a jigsaw. Ever get worried when the molten hot rotozip bit falls into the wall, I sure have:confused:
cowboyjwc
Simi Valley, CA
One more thing to be wary of: If you're not careful, it's possible to push half of a slat in where you're working, and pop out a hunk of plaster on the other side of the stud due to the slat see-sawing.
Don't ask me how I know. :roll:
I won't ask, because I found out the same way.:grin:
roger3829
Torrington, CT
I've always used metal old work boxes and madison bars. The metal boxes are much smaller and leave more room for crumbling plaster. I use a screwdriver to chip away the plaster and then a hacksaw blade (32 tpi) to cut the lath. Works very well. Have been doing this for over 30 years...:)
