Cutting Rigid metal conduit.
That was with a ready set go, and I must admit i was thinking about a piece of rigid when I said it, not a ten foot stick.
What size do we switch from "stick" to "log" or to "trunk"?
1/2 EMT might be a stick, but 1 inch RMC has to at least be a sapling:)
At my age, it is all a stick when I am requesting that an apprentice run on over to the pile and pick one up.:thumbsup:
Bolt a vice on your bumper or a bench table if the job warrants it and use a saw-zaw or band saw (portable) if the cuts ain't stay straight consistently. I can use those tools freehand 95 percent of the time without issues for short jobs if your making a lot of cuts use the vice to avoid to much waste.
Most guys can't cut the pipe straight enough with any type of hand held saw, so on my jobs you will use a pipe cutter.
Agree - I can cut straight but if you include time to change blades the Rigid type pipe cutter shown in a previous photo coupled with power threader and a reamer on a stand beats cutting anytime IMO.
My old Pipe Master power threader has an integral cutter and reamer so you do not even have to pickup different tools. I have never saw cut a pipe or conduit when this type tool is nearby.
