Looking for advice on dealing with new customers with existing code violations who don't want to spend the money to fix things. Most of my work is commercial/Industrial and I find that in my area inspectors are more likely to overlook a lot of things in these types of settings or if it's a building they've been to 100 times they don't even bother taking a look around. Because of this when I bring something to a building owner's attention I got the answer we all get " it's been like that for 20 years and nobody's said anything" or " I'll fix it when the inspector calls me on it" ... Obviously I guess it depends on the severity of issue but when you guys run into this kind of thing how do you handle it ? Do you refuse to do the work unless they agree to bring things up to code so you're covered the next time an inspector walks in and you were the last person there ? The problem I see is there are so many guys that will come in and do the work without even discussing code violations with the customer. I guess I should also specify but I'm talking about violations in systems that you are working on specifically not just walking around picking out things unrelated to your job
Sent from my Nexus 6P using Tapatalk
