pegggu
- Los Angeles
can someone briefly explain/summarize why the secondary on a wye system is 120/208v but a delta system is 120/240v (ignoring high leg and corner leg delta's)?
why is delta not 120/208v as well since it's also a 3 phase system?
and ignoring the high leg and corner leg delta's... delta only has a phase-phase voltage, which would be 240v, correct? there is no phase-neutral voltage if there is no neutral.
