charlietuna
I have never installed "Service Entrance Cable" and noticed on a friend's brand new house (under construction) installtion that the bond conductor in his main panel has three strands cut off the incoming aluminum conductor. I was under the understanding that this cable's design size is manufactured for "say" a 200 amp residential installation. Apparently, the installer cut the strands off to make it easier to slide under the ground bus's lug. And again, i am thinking this is a 200 amp residential panel and the "BOND BUS" terminal lug is (?) sized for "the" proper size bond conductor. Thanks for your input
