Despard switch
nizak
Does anyone know if you can get a 4 way configuration in a Despard switch?
I tried to pull up Legrand/ Pass and Seymour website but can't find their Despard product line.
Any help appreciated
Not for a four way configuration. The best you can find is for three way (three devices) that will mount in a single gang box.
Your solution is: mount a two-gang box with two 2-gang Despard switches.
Although rare, HD and other sites still sell them.
Matching switch plates are also available.
If Pass & Seymour doesn't carry them, try Cooper and fleabay.
Stud cavity width only allows for existing single gang box to be fished into. It already has a conventional 4 way switch in it.
Customer does not want another box added to the wall.
I guess it all depends on how bad they need/ want the convenience of the additional 3 way switching capability.
Standard building practices have 16 inch spacing between studs. Are you saying a two or three gang boxes would not fit between studs?
Not all studs are placed sixteen inches apart, especially near doors where it's common to put a switch.
I agree. . . there are instances where double studs make it impossible to install a two or three gang box next to the door jamb. The king stud next to the regular stud sometimes doesn't allow even for a single gang so the nearest one would be where the box would be mounted. It would be inconvenient to have the switch located two- stud spaces away.
You don't want to have someone groping in the dark to find the switch.
FWIW, my wife is a practicing (and registered) Architect. She has a bachelor degree in Architecture and I usually help her in electrical layouts for custom homes.
Works but butt ugly.
So might be placing a flush one gang above/below the existing location - pick which one you would rather live with.
Something low voltage or wireless is another possibility, may come with a higher price tag.
I don't really like to do it this way but when all else fails ( I'm not going to use wiremold boxes).
I draw out the box and remove the sheetrock and then remove as much of the stud as necessary for a 2-gang box to fit ( A may have some plumber's genes).
I am confused. What do you need by a '4 way' configuration?
Do you mean 4 switches packed into a single gang box, or do you mean a single '4 way' (DPDT) that fits into a Despard bracket?
If you mean a single 4 way switch, then do you really need it? '4 way' switches are used in the middle of a run with '3 way' switches at the ends of the line to permit switching from multiple locations. If you already have a '3 way' switch at your tightly constrained despard location, then make that the end of the run, and put the '4 way' switches where you have more space.
If you mean 4 switches packed into a single gang box, I don't think you will be able to do this with line voltage switches. If anything think about how crowded the wires would be!
-Jon
I need to have (1) 4way switch and (1) 3 way switch occupy the same single gang box. Was hoping to be able to get (1) Despard 3 way and (1) Despard 4way . Mount them in the Despard yoke and call it good.
Am finding Despard does not make a 4 way insert that snaps into their yokes
I wonder what the legality of using a switch such as this would be:
https://www.grainger.com/product/4X851
Though I doubt that the homeowner would go for it :)
IMHO the best approach (as I suggested above) would be to go with 2 3 way switches, and change the wiring so that your 4 way switch goes someplace else with more space. More fishing of wire, but then the device will fit and look good.
-Jon
That's real butt ugly and a lot of homeowner's are not going to go for it.
More potentially ugly options:)
DPDT AC/DC snap switches - the "bat handle" style switches, and a stainless blank cover, drill holes to mount switches into the plate.
Stainless blank cover once again and drill 22mm selector switches into it - though you do have to watch contact ratings of those, or drive a relay with the switches instead of directly controlling the load.
Make a 4 way despard switch from two 3 way switches
The evidence seems conclusive that nobody's making 4 way despard switches. If the 4 way switch you need to replace is in a box with one or two switches, you can replace the 4 way switch with two 3 way switches, and connect them with a piece of wire through a hole drilled in each switch handle, like a a 220V circuit breaker. The wiring looks like this:
x------,---------
---------x |
x---,--|---------
x---' |
---------x |
x------'
The schematic above is not what I typed. The blog software removes consecutive spaces. Click on "reply with quote" and then click on "switch editor to source mode". I looked on Google images. Dozens of wiring diagrams for hooking up 4 way switches. Not a single schematic of what's inside the switch. Sorry I don't have a scanner to attach a drawing.
Geeze, years ago you could get away with something like that because there was no allowance for clamps, yoke and grounding conductor. What's your box fill going to be?? 7 #14s, 2 for the yoke so 9 right there. Any clamps or grounding conductor? You say there isn't any room so how big can that box be? A single gang 3 1/2" deep will only handle 9 #14s so you are going to be over by 1 even with that box (which I doubt you have) unless you use connectors for the cables and AC, not Romex.
I have been in that situation several times and did what Growler did. Remove the sheetrock and hog out enough lumber to get a deep 1900 box and 2 gang ring in there.
Despards are really for replacement only, much like two-slot receptacles. I wouldn't even want to use them for replacement much less new.
-Hal
