Detached garage grounding
If you main building and separate building ground rods are closer than 6ft they are to be bonded together
You can not bond them together if less than 6'. I was thinking if the buildings are that close, run a GEC from garage panel to one of the ground rods. All you would have to do is protect it from damage.
>I believe it has to do with fire spreading.
????? Are they trying to make sure the fire spreads?
Kind of stupid isn't it? but at same time you made it become one structure instead of two, technically anyway.
I've also seen situations where separate garage was built then they said per zoning rules it wasn't set back from street far enough, yet allowed a breezway to connect it to the existing house that was grandfathered from the newer zoning distance:unsure:
