kmartinez5588
- Youngsville, Louisiana, U.S.A.
Hello all,
I'm new to this forum and fairly new to the electrical field, so please excuse my ignorance. I work on an offshore oil and gas production platform and was recently troubleshooting a condensing unit for the living quarters freezer. The unit has 3 phase 208VAC contactor that wasn't closing. Found the relay that controlled the coils was burnt, so I replaced it, and now it works again. But while I was in the box, I noticed that each phase coming to the load side of thecontactor had a different voltage reading than the other, but read 208VAC phase to phase. My readings phase to ground were: L1-93V...L2-143V...L3-236V. Went to the main panel and found the neutral to ground reading at 120V. The X-MFR feeding this panel is a Delta/Wye. Primary is 3 wire 480V Delta and Secondary is 4 wire 120/208V Wye. The X-MFR case has an earth ground connection, but noticed the XO wire connected to the Secondary neutral was not bonded to enclosure. Could this be the problem for the unbalanced loads and the 120V reading on my neutral to ground? I apologize for the long initial post but, I was trying to give as many details as possible. Thanks!
