wwhitney
- Berkeley, CA
- Retired
Of course. I meant that if you moved the electrodes farther apart, you'd get a new set of 6 pair-wise resistances, which should still be expressable as the pairwise sums of a new set of 4 electrode resistances. My thinking (perhaps wrongs) was that if distant earth resistance was non-zero, it would show up more at larger distances. So maybe it would be better to arrange the rods as a long skinny rectangle (but with the short edges large enough to avoid near-field effects.)It will be different as you have moved the rods and the rod to earth connection will not be the same.
Anyway, is the basic idea correct, that this is what is meant by the statement that the resistance of the earth itself is 0?
Cheers, Wayne
