I don't care if you personally hand delivered it, I'd bet a large sum that the information will not get much consideration from them though.If you all are ok with it, I'd like to forward a link to this thread over to customer support at NFPA, they should be getting this type of feedback from professional end-users.
Sent from my SCH-I535 using Tapatalk
I agree with kwire that the old cd rom had an extra layer in the chapter areas where you could go to the exact article and section number. With this setup you can only get to the beginning of each article. Thus if I wanted 250.122 I could only get to the beginning of art 250 and then scroll to 122.. PITA
Do a search for 250.122.............
No.Does the 2014 PDF use the fileopen plugin?
And it takes you to article 215 where 250.122 is mentioned. Besides you don't always know the exact article but if you see it it may help
That is what I liked about the older electronic versions, typing a search is handy if you don't know what you are looking for, but I often know what I am looking for don't know exactly where it is but do know approximately where it is. The menu tree can get you to where you want to be pretty quickly if you know about where to go, and just being close and reading section titles as you work through the menu often you recognize a section title and you then know exactly which section you want to go to.And it takes you to article 215 where 250.122 is mentioned. Besides you don't always know the exact article but if you see it it may help
I heard about a guy who downloaded all nec pdfs from torrent sharing website and he can bookmark it, highlight, edit, search and even view on iPhone without internet service. Or I heard about a guy who typed in 'nec 2011' in google search and the first link from top was a downloadable pdf.
Agree. FWIW, a legitimate PDF permits printing. One could print the entire PDF as an unprotected PDF then add their own bookmarks... but that's just it?they'd have to add all the bookmarks....
Probably pirated copies. NFPA protected their versions that they distribute to make them more difficult to redistribute, but I'm sure if you know what you are doing it can still be worked around. Other possibility is for someone to take the time to load every page of a hard copy and create their own file and distribute it. If I were to take the time to do that and distribute some copies (even though illegal) I don't think it would be worth my time unless I charged more then NFPA sells the official versions for.
I have a printer driver that is essentially a pdf converter, just send the entire document to such a utilityAgree. FWIW, a legitimate PDF permits printing. One could print the entire PDF as an unprotected PDF then add their own bookmarks... but that's just it?they'd have to add all the bookmarks.
That's what I was referring to... but bookmarks do not make it through the "print" process.I have a printer driver that is essentially a pdf converter, just send the entire document to such a utility![]()
Well the type he's referring to installs as a printer (i.e. print driver). After it's installed you just print from the application and choose the printer to create the PDF file. There are several available free: Foxit, CutePDF, etc. Adobe PDF is installed with the full or pro' version of Acrobat.What is a pdf converter?
Perhaps... but that's sorta the point of being able to add bookmarks. Besides, if there was a bookmark for every section, you'd spend just as much time scrolling bookmarks to get to where you want to go as just scrolling the pages. I have Acrobat set to show a single full page just for this purpose. When set to continuous pages, it takes forever to scroll the document. Using the scroll bar goes too fast. I suppose bookmarks for "Parts" may provide an advantage.What all ten of them?
Ok, there is more then that, but should be many more then there is.:happyyes:
