al hildenbrand
- Minnesota
- Electrical Contractor, Electrical Consultant, Electrical Engineer
Re: dimmers
Thanks Rattus,
That helps.
Over the years I've had the experience of introducing individuals to how a simple 600VA incandescent only solid state dimmer switches itself on and off. Again and again, the initiate will be expecting the dimmer to be working hardest when the dimmer is dimming the light to the lowest level.
It is my experience that the initiate intuits that the energy not getting to the bulb, has to be "somewhere", so it must be being "wasted" in the dimmer.
The increase of the voltage drop across the dimmer as the dimmer is closer to operating the bulb at maximum brightness, accentuates the counter-intuitive behavior of the dimmer.
That is, the dimmer is hottest when the bulb is the brightest while the triac is still in the circuit (not bypassed by the FULL ON mechanical switch present in most dimmers with mechanical controls).
Thanks Rattus,
That helps.
