gar
- Ann Arbor, Michigan
- EE
160308-0813 ESTPost #1 never made any mention of a breaker tripping. When was that brought up?.
From this I assume you want to provide dimming control of about 68 LED bulbs that have a steady-state actual power consumption of 9.5 W each or their equivalent in some larger size. This 650 W dimmer might allow about 10 incandescents rated at 60 W each. Lutron is saying that you can only control about 26 LEDs of 9.5 W each on the 650 W dimmer. You are still way ahead on light output for one dimmer.I am looking to dim 650W of LED lamps on one switchleg. From what I can discern, the best i can get for Lutron is 250W.
Dennis can you delete the contents of the previous version of this post where the plots were lost, and just inxert a note referencing this post?
George...
George...?
I didn't want to spoil all the fun; ask for the time, get detailed instructions on how to build a nuclear submarine. Another typical day on the forum. It may prove useful to some.
if you really want to dim LED's, then 0-10 volt dimmable devices is the most reliable
way to do it,
Leviton claims a 1000W dimmer for LED. Is there fine print I am missing, or is Lutron sucking wind on this particular front?
Edison base A19 LED replacements.
Dennis, educate me: power booster...?
Were these all on one switch leg originally? When you say 650W, was that the original incandescent wattage? If it was, your LED wattage will be much less.
I don't know how to say it more plainly, but here's another attempt:
72 lamps x 9 watts apiece = 648W.
There does not appear to be a dimmer that will handle this.
.72 lamps x 9 watts apiece = 648W
If I may ask, what kind of room has 72 lamps?I don't know how to say it more plainly, but here's another attempt:
