Becker Electric
- Los Angeles
- C-10
What are your thoughts, if your in a situation where you have to work live, about disconnecting the ground from a receptacle first. Of course generally first to make, last to break and all that but If you’re holding the yoke in one hand and unscrewing the hot wire with a screwdriver in the other, ungrounding the yoke might lower the chance of current passing through the chest in the event of accidentally touching the hot terminal, it'd seek ground through feet or another path or maybe not at all if you yourself are ungrounded. Any thoughts on this approach? What other risks may be more likely to happen by disconnecting the ground first?
