jph320
- Cinnaminson nj
- Electrician
I thought the max height for disconnects are 6'7? We have some heat pumps at work that you need a pole to reach the disconnect to shut it down.
Per '08 Code:% %
Would Exception # 3 be applicable for **jph320**?
Thanks!"Per '08 Code: I think exception 2 would be the most likely depending on the equipment location.
I doubt the switch he has would qualify as a "Switch-isolation" per NEC definition."
