Is there any code violation with taking 1 20amp circuit to a three way switch and off of one traveler hitting the disposal and off the other hitting the dishwasher so that there work simutaniously.
If you ran the dish washer off one traveler and the dish washer off another they could both be energized at the same time. when the dishwasher is running and you flip on the disposal the dish washer would shut off
Don't be. I think we're just saying the same thing differently.So you are running power to the common terminal first? If so, you cannot have both running at the same time.
I guess I'm con-fused.![]()
The confusion was because you meant "supplied" simultaneously, while we meant "energized" simultaneously.right they wouldnt run at the same time thats the point or else the circuit would more than likely be over loaded
So far, but give us time; the thread is young.Not a code violation in anyones opinion
most people would turn the disposal on and right off
It's easy enough when you're told (accurately) what apliances will be installed, and what their electrical requirements are.ok great...it is not wrong per the code but why would you want to do that when wiring a new house with fresh circuits???????????
