winnie
- Springfield, MA, USA
- Electric motor research
Did it open the contacts when you pressed "off" while not powered? If it is same working components as a GFCI receptacle (just no receptacles) I doubt it will.
I think that the way the 'test' and 'reset' buttons work has changed, but cannot find documentation.
Originally the 'test' button would trigger simulated fault current to trip the device. Of course the device would need to be powered for this to work.
Here is a link to a modern GFCI chip. https://www.ti.com/lit/ds/symlink/a...94809&ref_url=https%3A%2F%2Fwww.google.com%2F
At power-up and every 3 seconds the unit runs simulated fault current, and checks that it is detected.
I think the 'test' button in some GFCIs may be a simple mechanical off (unlike original designs, and not what the name suggests).
The 'test' then occurs during the reset sequence.
-Jon
