- Massachusetts
Those examples are all accessible, but likely are not "readily accessible". GFCI's must be "readily accessible".
You are absolutely correct, I was wrong in the post ahead of yours.:ashamed1:
210.8 Ground-Fault Circuit-Interrupter Protection for
Personnel. Ground-fault circuit-interruption for personnel
shall be provided as required in 210.8(A) through (C). The
ground-fault circuit-interrupter shall be installed in a
readily accessible location.
I knew jrannis had the wrong definition but so did I.
Here is the correct one.
Accessible, Readily (Readily Accessible). Capable of being
reached quickly for operation, renewal, or inspections
without requiring those to whom ready access is requisite
to climb over or remove obstacles or to resort to portable
ladders, and so forth.
