do you have link for unistrut large size cable strap?1. Hanging we would use a Victor split or a strut strap to an existing rack.
2. On the floor just gravity.
Structure engineer needs to involve if EC suspend cable with unistrut & cable clamp/strap from structure above?
I guess that depends on where you're hanging it. In a plant there might be someone who cares how it's suspended but on a construction site no.Structure engineer needs to involve if EC suspend cable with unistrut & cable clamp/strap from structure above?
With very high current and assuming that the strut and strut strap are ferrous, I can see a potential for inductive heating at the support point assuming there is only a single AC conductor run through the porcelain. Probably not a real world issue unless the current on the conductor exceeds 400 amps.
I'm pretty sure someone makes a strap/insulator that would fit the 3 cables in one strap. Besides the theoretical issue you've mentioned I've never seen a problem in the field even when the conductors are individually strapped.With very high current and assuming that the strut and strut strap are ferrous, I can see a potential for inductive heating at the support point assuming there is only a single AC conductor run through the porcelain. Probably not a real world issue unless the current on the conductor exceeds 400 amps.
I have seen this arrangement on 5kv cables where the straps were noticeably warm, but not hot enough to damage. Not sure what the current on the 5kv cables was.I'm pretty sure someone makes a strap/insulator that would fit the 3 cables in one strap. Besides the theoretical issue you've mentioned I've never seen a problem in the field even when the conductors are individually strapped.
