- Massachusetts
So I find this flexable PVC elbow. It's made up out of two PVC FAs, two carflex connectors and a chunk of carflex.
If I made this myself for sure people would call it a 110.3 violation.
Exactly, one can use all the same components to build a similar thing and still be within the listing of those components. This just happens to be an assembly that is listed as is.110.3B simply means usage according to listing.....
~RJ~
The difference is the flex elbow is listed.
I bet most inspectors would accept a setup that you put together with 2 carflex connectors and threaded couplings
What is not being for what it is intended for - even if you build your own "flex coupling"?Exactly
Most? In my area for sure. But that still leaves a great many that would have a problem with it.
I make up my own changeovers all the time but on these forums we see the same questions come up time and again about using fittings in ways not directly intended for.
Bob,
Do you have the UL "E" number for the "listed assembly"?
PS It is listed under QQYZ "Wiring Assemblies." The first sentence of the guideinfo is "This category covers prefabricated wiring systems comprised of certified electrical components that could be field assembled and inspected by an Authority Having Jurisdiction (AHJ), but are assembled in the factory prior to field installation."It lists UL file number E 171248.
I'm not Bob, but here's the product page:
http://www.tnb.com/ps/fulltilt/index.cgi?part=UAFAE
Cheers, Wayne
Right there is the money quote. A field assembly would be just as acceptable and NOT a violation.
We hear of a lot of things being shot down that just don't make sense to many. Inspectors come in smart versions as well as not so smart versions just like electricians doIt seems I may be misunderstood.
My position is it should not a be violation of any kind.
The reality is that on these forums we hear of electricians being shot down for this very type of thing.
That is because no male connector has ever been evaluated for use with female threads. Some AHJs see that as a use outside the listing and a 110.3(B) violation.It seems I may be misunderstood.
The death penalty for a code violation? That seems harsh.The reality is that on these forums we hear of electricians being shot down for this very type of thing.
