jumper
- 3 Hr 2 Min from Winged Horses
The death penalty for a code violation? That seems harsh.
Dem Yankees play rough up there.
That is because no male connector has ever been evaluated for use with female threads. Some AHJs see that as a use outside the listing and a 110.3(B) violation.
It is something I have done thousands of times. I would bet a very small percentage of the LFMC connectors that I have installed have been used in the way that they have been evaluated for...that is with lock nuts.
Because connectors are designed to be installed in non-threaded enclosures using a lock nut. There was no reason to evaluate the connectors for an application other that what they are intended for.WOW! A male fitting mating with a female fitting is "Fittings 101". How does anyone ever miss evaluating that obvious combination for basic electromech continuity?
Violation or not, I can't think of a place I would use them. After a year or two in the sun carflex isn't all that flexible, the gaskets will be rotted away and if I bury, sch 40 is easy enough to bend.
I haven't seen them pushed at any of my supply houses. For DIYers only.
Dem Yankees play rough up there.![]()
One of my 20 something female office help asked me the difference between the two. The look on my face as I prepared to explain must have been a clue. She turned pink and said "Never mind, I get it."WOW! A male fitting mating with a female fitting is "Fittings 101". How does anyone ever miss evaluating that obvious combination for basic electromech continuity?
hey. it's a tough crowd. 100 watt lightbulbs in calif. are a felony.
Grounding/bonding may be an issue for metallic fittings if you put a straght thread fitting into it instead of tapered thread of RMC/IMC and I understand that concern but that isn't an issue with a non metallic fitting.WOW! A male fitting mating with a female fitting is "Fittings 101". How does anyone ever miss evaluating that obvious combination for basic electromech continuity?
Apparently PVC female adapters are for use to adapt to tapered thread only, which mostly limits us to threaded RMC/IMC?
I make change overs all the time using rigid couplings and straight thread fittings and have no issue with it myself, but supposedly they are not listed for that. Just did some the other day - IMC to LT flex as final connection to some motors.After working with UL listed push in MCap cable connectors http://www.aifittings.com/catalog/flex-ac-mc/snap2it-connectors/ and numerous other dubious connections that pass UL grounding tests I am confident any of the change overs I have field made would work fine.
XLR balanced audio connectors are the same way. Are the three small pins inside the shell the "male" part(s), or is the larger cylindrical part that fits into the other shell what determines its gender? Since the three pins point in the direction of signal flow most of the time, I believe they are "male".Well at least this male/female designation is obvious.
With Multicontact and Amphenol connectors for PV wiring, it is much more confusing to learn the convention. The part that looks female externally, is actually a male connector. Because the metal pin, not the plastic shell, establishes the connector gender. I had a co-worker explain why that connector is male, and he said "let me put it this way, it's an intact male if you know what I mean".
They are confused don't know what gender they truly are and really need some professional counselingXLR balanced audio connectors are the same way. Are the three small pins inside the shell the "male" part(s), or is the larger cylindrical part that fits into the other shell what determines its gender? Since the three pins point in the direction of signal flow most of the time, I believe they are "male".
They are confused don't know what gender they truly are and really need some professional counseling![]()
