allenwayne
celtic said:I'll show my cards:
What your are looking at is the #8's from the load side of my 50A FPE Main....they enter this KO and goto a backfed 50A CB in a 200A panel with a 200A MCB.
Is it "safe"?
Yes
Is it legal?
Let's not even open that can of worms!
Here is a shot looking at the new panel.
You can see the #8's coming in the side there....next to the water lineson the right, a small wall will be built there - not because it has to be, but because I want it to be ~ if that water line or the filters should ever burst(that is an exterior wall in the basement) I don't my panel getting wet. In addition to that planned wall, the water line was relocated from directly over the panel to a location 4' out from the face of the panel - not a code requirement, but I strongly dislike water dripping onto a panel or person working on the panel.
Now for your amusement is the "transition area".
In the top left of the picture are 4 runs of 3/4" EMT that goto a 12x12 JB. This is not by any means a requirement - it is for me. The panel is completely wired, every breaker (with the exception of the 50A backfed CB and the 200A MCB) has wires landed on them. I have taken the liberty of determining that when I gut the kitchen, all I will need to do is run 1 3/4" conduit to that area (in the basement) and then run up to the kitchen locations with romex...easy as pie. For my AC needs, same thing, 1 3/4" EMT from the JB to the disco...done...easy as pie. Same for when I finish the basement....2 3/4" EMTs ~ one east/west on south side; one east/west on north side both from the JB....done...easy as pie. There will be plenty of "extra room" in these conduits should I decide to add any exterior landscape lighting/recpts in the backyard area.
Having that JB there...and a plan...will make my future plans a breeze.
That entire wall where the meter and 50A FPE MCB are will be demoed...all that will remain will be the sump pit and pump below ~ you can just make out the pumps piping in the lower left...and you need to stand on the pit's cover to read the meter; and a central vac on yet another wall that needs to be built ~ extended from just right of the that grey pipe on the right (from the gutters/leaders).
Is it pretty...no, it's an ugly duckling...soon to be a swan.
Is it legal...not yet, but the foundation is in place.
So to answer your question:
Do Electricians have the worst wired homes?
Yes...
...but we are no worse off than the cobbler's kids.
Hey all that is is a temp situation in progress
