ceb58
- Raeford, NC
rich000 said:No. Put a thermometer in the room without the fan running and check the temperature. Turn on the fan and then check the temperature.
Tell us what you find out.
CFs cool by windchill. Inanimate objects do not feel windchill. You need water to experience wind chill.
Now, if you use a wet bulb thermometer, you might get a different temperature.
However, the home's air conditioner uses a thermostat that is probably not a wet bulb.
So, if you leave the room, turn off the fan.
The correct way to test the air is with a device called a sling psychrometer. It has two thermometers one is dry the other you wet a cotton ball that is wrapped around the bulb. The thermometer is attached to a string and handle you then twrill this contraption around for about a minute then read the two temps. If the ambient temp. is say 90 the wet one will be around 4-6 deg. cooler. As many have stated its the evaporating effect on your skin that makes it seem cooler. They use the same principle in chicken houses they have misters spraying a fine mist of water with large fans pulling air through the building feels good on a 100 deg. day:grin:
