- Lockport, IL
- Semi-Retired Electrical Engineer
Re: Does an electrical room have to be fire rated?
Imagine a room that is 6 x 12.5 feet. In the center of the 12.5 foot back wall, you mount a 6.5 foot wide, 18 inch deep panel that is rated at 480/277 volts and at 1200 amps, and that has circuit breakers. This meets the description of "large equipment." It needs an entrance at each end of the working space. But what is an "end"?
Draw a picture of this setup on a sheet of paper. Use a scale of 1 inch represents 1 foot. Show the view as seen from the ceiling. Draw a box 6 inches high and 12.5 inches wide. Center the panel in the wall at the top of your sketch, making it 6.5 inches wide and 1.5 inches deep. Label the wall at the top of the sketch as the North wall, so that the wall at the bottom is South, the wall at the right is East, and the wall at the left is West.
Now draw dashed lines to show the working space around the panel. You will have a rectangle that is exactly as wide as the panel (6.5 inches) and is 3.5 inches deep (representing 42 inches of required working space). Label the dashed line at the left side of the working space as "West Edge," the dashed line at the right side of the working space as "East Edge," and the dashed line at the bottom as "South Edge."
Questions:
</font>
Questions:
</font>
- <font size="2" face="Verdana, Helvetica, sans-serif">You have three "edges" of this working space. Which ones are addressed in the code statement, (you need an entrance) "at each end of the working space"? Must it be the East Edge and the West Edge? Must there be three entrances to the working space, since there are three edges?</font>
- <font size="2" face="Verdana, Helvetica, sans-serif">Can you say that the East Edge of the working space has an entrance that is 42 inches wide and is the same height as the room (since there is no obstruction anywhere along the East Edge), and can you say that there is no door in that East Edge? Can you say the same about the West Edge?</font>
- <font size="2" face="Verdana, Helvetica, sans-serif">Can you say that the South Edge of the working space has an entrance that is 6.5 feet wide and is the same height as the room, and can you also say there is no door in that South Edge?</font>
- <font size="2" face="Verdana, Helvetica, sans-serif">You have four walls to the room. There is physical space in each of the walls to support a 2 foot wide doorway. Can you pick any two walls and put one door in each, and satisfy the rule?</font>
- <font size="2" face="Verdana, Helvetica, sans-serif">If you put a door on the East wall and a door in the South wall, does this satisfy the rule about "at each end of the working space"?</font>
- <font size="2" face="Verdana, Helvetica, sans-serif">Can you put two doors in the South wall, one to the far right and one to the far left, and satisfy the rule?</font>
- <font size="2" face="Verdana, Helvetica, sans-serif">Can you put two doors in the North wall, one to the right of the panel and one to the left of the panel, and satisfy the rule?</font>
