AL wire is it's own separate issue. We don't allow it locally. I don't think it's worthwhile for anything other than feeders/SECs, but even that's not allowed locally.I company I work for had an issue with some 14-50's at a senior living condo complex, our guys cut the cable so the terminations stayed on there (they were pretty baked but not as bad as other's I have seen recently) then the owner had them sent them to the manufacturer at his own expense, he's a demanding guy and likes to get to the bottom of stuff. There was some back and forth about the chargers, the settings and the brand then nothing and about a year or more later the manufacturer said the issue was with the aluminum terminations, I think they asked if they had been greased with noalox . All the new heavy duty EV receptacles now have silently dropped support for aluminum cable.
They are CU only.
Same issue as house outlets and AL wire in the 1970's IMO.
The entire thread is about neutral pins not 1450s burning up, keep up. Come back to me with facts.Says the entirety of this thread.
There is 1 prior post about a 1450 meltdown, and it fits with my general vibe here:
- The primary issue is the cheap Leviton 1450 (and likely other generics)
- Bad wiring/terminations will also cause it (and same for any outlet)
- 90% of "my EV outlet melted down" posts that I've seen online are all Levitons
Did this EV business all start with Leviton outlets burning up then Leviton coming out with a special EV outlet, then all the other brands following suit sensing a fresh business opportunity? Maybe it speaks more to Leviton specifically rather than all 1450s...
