Not with a separate line item but they are most definitely charged.
Then why add an additional line item? You almost seem to be agreeing with me that the additional demand charge is unreasonable.
You simply have to understand utility cost allocation and it does not appear you do. However, that is not your fault as many do not understand it.
It does not appear that you are interested in actually responding to what I have been saying in this thread. But perhaps that is not your fault, because it would be difficult to refute what I'm saying.
If the solar power were as reliable and as cost effective as the other peaking units, they should be compensated. But the problem is they are not the same. You can't replace a van with a compact, or replace a motorcycle with a bicycle, etc. Each has a niche but are not one-for-one replacements.
That would be a perfectly good argument in favor of adjusting net-metering rates. (I'm surprised that you have not said as much in this thread already.) It is not a good argument for a 'standby' charge based on customer power demand.
How about if the government ordered that you let me store my annual use of water at your house for a year? It really is no cost to you since I will pick it up a year later and you will wind up with the same net of space you have today. You may not have room to store my water, but I am still using you like a storage facility.
Right now nobody is storing anything, as you know. Solar reduces power demand from the utility's point of view, with the exception of vars.
Not true.
Not true either.
Not true.
I doubt it.
Wow. Those are some exceptionally powerful arguments, both well stated in explanatory terms and well supported by sources. Yes, I am being sarcastic.
The rates try to model the costs while we try to use the most cost-effective means to gather the billing determinates and render a bill.
Assessing solar system owners with an additional demand-based charge is not a step forward in rationalizing rates, because the power demand of solar system owner is the same or less than any other customer.
Rate design is not a perfect science and there are no perfect solutions. I simply do not think you have the expertise to determine the correct direction and certainly are in no position to make a determination as to the right or wrong direction.
You are giving me no reason to believe that I lack enough expertise to have an informed opinion on this matter, because instead of responding to my arguments with facts and explanations, you are simply belittling me. It is a fallacious ad-hominem argument.
Of course, everybody is entitled to an opinion but that is usually far from an expert analysis. The charge has already been analyzed by rate experts both for and against the charge.
You mean those 'rate experts' called Virginia legislators? Who do you really think is better equipped to both gain the ear of and make the argument to those legislators? Dominion's lawyers, or residential solar system owners? Whose interests do you think are likely to hold sway? I think the answer to this is obvious to most people.
Yet you hurl insults at the workers, the auditors, the lawmakers, etc, cast dispersions on their integrity, accuse them of criminal activity, and bring their morals into question with no factual basis. You build a case out of fear, misunderstanding, misinformation, etc., but want to question my tone when I call your position and knowledge into question?
Oh for goodness sakes. I certainly left the workers and the auditors out of it, and I certainly accused no one of criminal activity. I have questioned the expertise of the Virginia legislators, and the motives of Dominion executives only. And given that we live in a democracy and all have a duty to be vigilant against the abuse of power (something our nation was formed to resist), I do not see any need to step back from making these kinds of statements, unless real explanations are given - not mere assertions - as to why the policies in question are justified.
If you can't make more honest arguments than this, well then, I'm wasting my time here. But if it makes you happy, I would be fine with leaving the motives and morals of the aforementioned people out of this thread, as long as you would respond with actual information about power demand instead of belittling my knowledge. If you are really in a better position to understand the issues, you will show it, not just baldly assert it.
Accept it or not, that is the way it is.
That's not how people have to think in a free country.
Start listening to the other things I have said, and I'll see if you can learn something about how things really work, and not at the normal fee I charge for classes, but for free
I am still waiting for you to explain to me how installing a solar system affects a customer's power demand at night. Or, for that matter, during the day. I would be genuinely appreciative of the time you are taking responding to me in this thread if your replies were more enlightening and less insulting.
