- Tennessee NEC:2017
- Semi-Retired Electrician
If you have line and load conductors reversed newer units will not reset either, fairly certain this is a listing requirement.
That very well could have been the issue, it was a pre existing problem at a friends house. I may have over looked that initially and then when I replaced it wired it correctly and it was able to reset, and then when I placed the old one on it worked as well cuz I did that one correctly too
Hmmm, post #12 must have been invisible.
I see now, sorry about that, you were correct
