Mustang125
- New Hampshire
- Master Electrician, Project Manager and Estimator
not sure why you are part of an internet forum then...If you are adding phase currents to come up with line current, you do not understand the system. I don't have an issue with you trying to learn more; I am encouraging you to do some research on how this stuff works instead of relying on answers from an internet forum.
The correct response would be "hey buddy it looks like you mis-calculated your phase amps, this is how you should do it next time"
you could do all the research in the world and still mis a small detail that throws everything off, like i did, i used 3ph math when calculating the per phase load. simple mistake anyone could make if not in the grove of the math.
