hhsting
- Glen bunie, md, us
- Junior plan reviewer
Definition of effective ground fault current path: an intentionally constructed, low impedance electrically conductive path designed and intended to carry current under ground fault conditions from the point of ground fault on a wiring system to the electrical supply source and that facilitates the operation of the overcurrent protective device or ground fault detectors.
Definition of equipment grounding conductor: the conductive path that provides a ground fault current path and connects normally non current metal parts of equipment together and to the system grounded conductor or to the grounding electrode conductor or both.
Questions:
1. Where in NEC 2014 it says EGC can be used to create effective ground fault current path?
2. If I have metallic poles one line separated by x distance and each pole has power equipment attached and light that dedicated branch circuits in them and EGC for all of them are bonded to its respective metallic pole then would that be creating effective ground fault current or just ground fault current?
Questions:
