hhsting
 - Glen bunie, md, us
 - Junior plan reviewer
I feel like this is a separate topic then one on the post bringing both EGC and IGC so needs to have separate post not in same post to avoid confusion.
I have two menu boards and I have two lights lights outside fed from panelboard inside but has pull box in between.
So from panelboard to pull box inside I have 8#10+8#12+1#10EGC + 1#10IGC all in one conduit for two menu boards and two lights outside. All loads fed from 20A branch circuit breakers 120V single phase.
From pullbox they separate: for two lights I have 4#12+2#12EGC+2#12IGC separate conduit and for two menu boards I have 4#10+2#10EGC+2#10IGC in separate conduit.
So from incoming to pull box it’s #10EGC and #10IGC but then they split to #12EGC, #12IGC for lights but remain #10EGC , #10IGC for menu boards .
Can you tap size from#10 to #12 as mention above EGC and IGC for lights?
