K8MHZ
- Electrician
This is how I deal with this.
White wires on breakers get re-identified before they are removed( I use red tape, it shows up real well ). I take a book of wire numbers and make sure that each circuit conductor is marked before it's removed. With new panel everything is placed back exactly where it was in the old panel.
Once you have changed out the panel any trouble -shooting that is needed is a seperate charge as this is not part of the panel change.
A switch leg make up in the panel is not that odd. Where you would normally see this is where a time clock was added to control a lighting circuit.
For the white wires, I use red tape for the left hot conductor circuit and blue for the right, using a meter to verify before I disconnect. I've seen some screwy 240 volt circuits bugged into panels and it's way quicker be red and blue verified when it's time to try to make them work after they have been pulled out and put in a new panel.
