Electric Baseboard Heat
I noticed the reader had to supply their own decimal point. Not a problem for me.
The "aw_$h__ is more than out-weighed by the atta-boy for being the only one that has pointed out that the "rules of thumb" only work if:
1. you only do work in one area
2. you only work on one building type/formfactor.
You're absolutely right - heat loss is a function of differential temp, wind speed, outside surface area, insulation, insulation factors for windows and doors/number of doors and windows.
cf
I feel the need to address some of this, because much of it simply doesn't apply to the topic of electric baseboard heaters.
If you run the programs, you can see that the different parts of the country vary widely in the amount of heat needed to be supplied to any given structure.
For example, a 1250 sq. ft home built in Texas might require 63,521,600 Btu/h per hour where that same home in Mn could require 81,115,100 Btu/hour to heat.
Assuming that a 1 watt = 3412 Btu/h, the Tx home would require 18.6 Kva of heating, and the Mn home would require 23.8 Kva of heating.
When translated to electric baseboard heaters, distributed throughout the home, it will more than likely yield nearly the same heaters in the same locations.
And also consider that oversizing is no longer considered acceptable. So just assuming say 15 watts/SF will keep them warm may produce a red tag just as readily as undersizing.
Plainly untrue in the case of electric baseboard heaters. You can oversize all you want. You may also undersize as long as your design can maintain 68 degrees. If you have a code section in mind that precludes oversizing baseboard heat, I'd invite you to post it here, whether it be IRC or otherwise. It does not exist. The stat will simply run the heat for a shorter amount of time.
(cut) When translated to electric baseboard heaters, distributed throughout the home, it will more than likely yield nearly the same heaters in the same locations. (cut)
Lost me on this one. MN needs 95 feet, TX needs 72 feet. Are you over-buying by 1/3 in TX or are you under-buying by a 1/4 in MN?
cf
Do a room by room layout and call me later. You're a goofball.
Whoop! Whoop! High post count arrogance factor alert!
And you guys wonder why mule doesn't want anything to do with you. It's clear to me.
As for me being a "goofball' - I don't know what to say - technically "nope, I don't sniff". Practically, "Yeah sometimes - so what";)
but I still don't get why one would want to buy extra heat when not needed - nor undersize to the point of poor recovery. Without any explanation, it appears to be poor tradesmanship to me.
But I also don't do residential either.
Sorry to hit and run, but I only get a few hours every now and then to look at this. Back to work for me.
cf
When they start making baseboard heaters in boutique sizes, then you might be right. Until then, unless you're operating in the most extreme northern or southern climates, the install will look pretty much the same in most of the country.
Who said anything about it being undersized?
The explanation is simple, the opening poster asked if there was a rule of thumb and the answer is yes, there are rules of thumb.
I think we all know that to figure heat or cooling load exactly requires more than a simple watts to area calculation but for electric heat it can be done.
That seems like a long stretch to me.
