Different voltage. You assumed 208V, mayanees assumed 480V.I ran it on Bussmann' FC2 app... may have made a mistake....
The larger unit heaters have contactors, fuses, etc. to cycle and protect the heating elements. If I built an industrial control panel to cycle heating elements, I believe it would require an SCCR rating. If these devices are inside the heating unit it doesn't seem to apply. That I don't understand.SCCR applies to devices that switch or control or protect (by switching). It doesn't apply to end USE devices like motors or heaters.
Yes, that would be true.The larger unit heaters have contactors, fuses, etc. to cycle and protect the heating elements. If I built an industrial control panel to cycle heating elements, I believe it would require an SCCR rating. If these devices are inside the heating unit it doesn't seem to apply. That I don't understand.
