Electrical Classification per state
One of the benefits of the licensing structure we have here in NJ, a unified adopted code. One license, entire state, no town or city can adopt their own "code" or licensing scheme.
Same in Washington, and many cities that do their own inspections around Seattle (Bellvue, Kirkland etc have a common set of admendments to the NEC, that makes it easier for a contractor to work in different areas. Also if you need a business license for different cities, its is easily added to your state master business license.
Somewhat have that here. All licensing is done at state level. Cities that do have their own permitting/inspections do not issue licenses. They do require you hold a state license (can be one that state has allowed via reciprocation from other states) but most those cities still want you to register with them and submit a registration fee - of course you need to resubmit every two years when your state license needs to be renewed. Those cities can have their own amendments, but according to state law they can not lessen state requirements (which is NEC with no amendments right now). So one example is a city can't decide they want to eliminate some or all NEC AFCI requirements, but they could add more AFCI requirements if they wanted to.
Interesting. I asked two Class I Contractors I know, they both said their licenses cover 400A.
So either that’s out of date, my friends are wrong, or they reversed back to 200A.
I will investigate.
I found another document from the construction industry licensing board that did say a class one license (Georgia) covers up to 400 amps.
I would assume that if the state upped the limit of class one to 400 amps they would never reverse it so you must be right. It would make sense because a lot of new residential construction does now have a 400 amp service.
It appears that I have learned something new.
Several years ago, there was talk amongst the construction board members of adding a journeyman license In Georgia, but it did not gain any steam.
How do they determine you are eligible to obtain a contractor license? Often holding a journeyman license for a certain amount of time is a determining factor in being eligible to apply to get a contractor license. Not that there isn't other ways to determine one might be eligible but is kind of the most common way of making this determination.
You have to submit proof of experience to the state board. I think it's still four years. If they determine you have met the experience requirement then you are allowed to take the test for a contractors license.
Back when I took the test many of the guys had at least 10 years of experience and some as many as 30 years. A few years ago not that many electricians wanted a license unless the were going into business. These days a lot of younger guys want a license as early as they can get it.
That is about the experience needed here to get a journeyman license (actually I think it is 5 but if you complete an approved 2 year school program they give you a free year so it can be done in 4). Having held an apprentice certificate for those years makes them easier to verify, though experience is not limited to being registered apprentice. Working in similar field for military is definitely acceptable experience.
Here to be eligible to apply for contractor license you must have held journeyman license for at least one year. May be exceptions where if you can prove the experience somehow, those will be case by case AFAIK.
In the long island, there are 2 counties, Nassau and Suffolk. Suffolk as one license. Nassau has numerous licenses. We have tried for years to have them change that for years. Not one of the different towns will not change. The reason is only one. Money. Each town charges money for the license.
In Massachusetts a journeyman can own/run his own business with one apprentice. And a master can hire journeyman. That’s the only difference between the two.
Sent from my iPhone using Tapatalk Pro
