kwired
Electron manager
- NE Nebraska
Just saying "Electrical Fire" is too generic and can have 10 different meanings to 10 different people.
If fire starts by something powered by electricity we have an electrical fire even if the problem was not electrical in nature. You know how many electric motors have started "electrical fires" but the real cause was a bad bearing or other mechanical problem?
If you overheat something with an appliance that is intended to create heat and start a fire is this an electrical fire or is there operator error involved. Good example may be a grease fire on a cooking stove. Does it matter if the heat source was from an electric element or from gas burner? The fire likely started because of something the cook did.
Say a structure fire starts out in a natural gas furnace, maybe there was an electrical failure that failed to turn off the gas and the result was excessive heat being supplied by the gas. Is this an "electrical fire" or just a malfunctioning appliance? One description sends different meaning than the other to most people.
