As an electrical inspector, I have written violations on an electrical contractors work and sent them to him. The EC contends that the homeowner will not allow him back in to his house to make these corrections. (I think the HO is unwilling to pay out any more cash, having paid too much already.) Whose responsibility is it to get the ball rolling? Must I do something more or is it the EC responsibility to get the HO to open his door in order to correct the violations?
Thanks
First I want to ask: are these violations related to the permit?
If they are related to the permit, the HO is not obligated to pay more.
I'm asking this, because I had a few situations where the inspector wouldn't give me a final because (for instance) existing conduits (that were not even close to our scope of work) were not properly supported. or not giving me a final because the receptacles outside did not have bubble covers (when we didn't even come close to those circuits or devices). Or an inspector who wanted me to tamper proof the whole house even though our permit was to remodel the kitchen.
Last, in South Florida if you pull a permit there's certain things that are required to be brought up to code, like SD and GFI in the bathrooms. Every city enforces it differently. For instance Deerfield Beach will require the bathroom receptacles to be replaced with GFI's, but won't enforce the SD requirement. Hallandale beach will MAKE YOU do the smoke detectors.
So which one is it?
1: Electrician failed on the work he did? In this case the owner should not be obligated to pay more money. In our area if an EC doesn't have a final and the permit expires, that said EC can not pull anymore permits with that city(so it's a pretty good deterrant. Not sure if your city has same policy)
2: Are you asking the HO to fix things that are not related to the permit, nor are required to be brought up to code by any state and/or local codes? In this case I believe you should give the EC his final and send code enforcement to write a violation to the HO.
3: Is it because required "up to code upgrades" that the "LOWEST BIDDER" was ignorant about, or thought he'd get away with? In this case I'd say do your worse to the EC. I'm tired of these low bidders thinking they'll make a quick buck, then try to rip off the customer.
