Pierre C Belarge
 - Westchester County, New York
Augie
Sounds like you are going to need 70E to enter your garage....
Only if he is being paid to do it.Augie
Sounds like you are going to need 70E to enter your garage....![]()
I have this situation in my home built in 1955. No inspection when built. I found a copy of a 1950's code book here...http://www.lindahall.org/. It just states "Electrical panels shall not be located in the vicinity of easily ignitable material" or similar verbiage. Isn't "Clothes closet" mentioned specifically in todays code ?
I couldn't find the link![]()
How do I view the book for free?
Not always that simple. I have done several buildings both residential and non residential that have entry below grade and therefore nothing on outside to give you much for clues on where point of entry is. Typical buildings in cities/villages often have meter on the building and then you have a good idea, but when meter is not on the building all bets are off as to where entry is and it could even be below slab or basement floor and emerge in an interior location.You find the main by seeing where the service enters the house. Something easily observable from outside of the house. If there is no main there, it's going to be just inside the home near that point. Sure, you might have to look around for clues, but it shouldn't take longer than a minute or two.
My larger point is that people who are looking for it usually can pick up clues on where to find it. And people who live in the house should locate it before they sleep in the house for the first time.
Well, I was being slightly facetious. I do live in MA after all where houses still stand with the first generation of electrical systems still intact.
