Body resistance may reduce with feet/legs submerged in water so that there is greater risk of electrocution.No water above typical outlet level so mostl likely OK for power inside the houses.
How does being sick reduce skin resistance?
To determine a person's total resistance, just add together the resistance of each part of the body - remember that the electricity must pass through the skin twice (on the way in and on the way out,), so the total resistance is:The most important factor affecting human electrocution is skin-resistance! so, if one is ill, sweating or immersed in water the risk is high!
Not too likely to find two people with exactly same resistance I would think. A majority will fall within a certain range though.To determine a person's total resistance, just add together the resistance of each part of the body - remember that the electricity must pass through the skin twice (on the way in and on the way out,), so the total resistance is:
Rtotal = Rskin(in) + Rinternal + Rskin(out)
If the Rskin(out) is in the feet/legs submerged in water, it will be lower and so Rtotal will also be lower and hence the risk of electrocution greater.
When your nurse gives you a sponge bath and she doesn't dry you completely.![]()
