electrician hand tools?
I have always used kliens 9" linemans pliers
I have used oil on them to loosen them , graphite also, and before that I would just work them and work them but that took a long time
I buy them bare if I can or just with comfort grips and then cut those off and get the red grips that are sold seperately , I know the instructions say to boil them but I hammer them on with a peice of wood -that way they are tight -
one time I even ground and sanded them untill they looked chrome but someone liked them more than me and stole them ( a lot of work for nothin)
I use all klien tools except for channel locks
I couldn't answer right off any preference so I picked up a pair pf 9" Kliens.
Turns out I put my pinky on the inside of the handle and control the opening that way.
It's amazing what you do unconciously and out of habit.
And I never heard about hitting the guy on the pole; I guess I just flailed away and beat the crud out of both sides, judging by the marks. Good information though....
RHaggie said:
... I never heard about hitting the guy on the pole;....
What Guy on the pole? ;) You all must be better than me because my Klein 9", 20+yrs, has no guy. I must have knocked him off the pole a few years back.
You are useing the SAME pair of lineman's for 20+ years ???
Either you like to carry every tool known to man or you aren't using the Klein's to maximum potential ;)
I buy a new set of 9's every couple of years...mostly because they stop cutting wire.
A sure fire why to wreck a pair of Klein's is to cut a snake or ASCR (ACSR?).
celtic said:
... you aren't using the Klein's to maximum potential ;)
I must admit that my Klein's don't cut like they did. It is amazing how you can become attached to your tools. There are quite a few battle scars that I can still remember today.
I'd say Klein would likely buy them back from you, to put in a display case out front! :D
I'm just about done with my fifth year in the field, once I settled on the Klein J-Man pliers I've managed to blow up or otherwise destroy two or three pair of them. You're not using them enough. :D
When I buy a new pair I try to determine nimbleness as much as I can while they're still in the package. I work them for up to ten minutes with WD-40 when I first buy them, and try to remember to work them once a month, but end up lubing them in longer intervals.
They fall open like it was their job.
The last pair I had seized up, and I snapped them hitting them with a hammer trying to free them up. So from here on out I'm on a regular lube policy and life is golden. :)
