Joe R said:
what if contractor "a" flat rate quotes ex. $200 to replace a gfi but finds out after he gets into the job the wiring is bad and the breaker has damage and the panel has a hot spot on the buss bar where the brkr stabs in and the panel needs replacement. does he break out the "book" and starts flat rate pricing the additional work, while the customer keeps saying "u said $200 to fix the problem
!" then what.
I charge a dispatch fee to go out and look things over. Then I quote a price only after I've looked things over. If the customer agrees with the price the dispatch fee is waived. If the customer doesn't agree with the price then I collect the dispatch fee and leave.
The first thing I do is go to the panels, pull the covers and check the condition of the panel, breakers and wiring. You can tell a lot from looking at the panels.
Then I take a quick look at the rest of the wiring. I look for broken receptacles, obvious code violations etc. This often tells me wether or not the wiring has had unqualified persons working on it. This can also generate extra work for you while you're already there. You can offer the customer discounts for the other work if he agrees to have it done while you're there.
I don't mention the other work until after I've solved the original problem.
After this then I would go to the GFCI recepatcle that's giving them the problem. If I was pretty certain the GFCI receptacle was bad I would explain to the customer that the GFCI receptacle appears to be bad and replacing it should solve the problem.
I would also explain to the customer that if for some reason this does not solve the problem that they will not be charged for me replacing the GFCI. If I find the wiring to the GFCI is bad and needs replaced I would quote them a price for that.
This way I'm only eating the cost for replacing the GFCI.
The same would be true if I quoted a price to install a light fixture and after I took the old fixture down I found the wiring was bad, needed repaired or someone ran lamp cord to the fixture. I would show this to the customer and quote a price for repairing or replacing the wiring. I would not do this as part of the fixture replacement quote.
If an auto mechanic quotes you a price to replace your brakes and after getting into the job he finds the rotors need turned he calls and explains that the rotors are bad and need turned or replaced and then quotes an additional amount for this.
Your car is running poorly and you take it to a mechanic. He tells you a tune-up should solve the problem and quotes you a price for the work.
The tune-up doesn't help and he looks further into the problem. He discovers the engine needs completely rebuilt.
Would you expect him to rebuild the engine at no cost because he said a tune-up should solve the problem?
Or would you expect him to not charge for the tune-up and quote you a price to have the engine rebuilt?
If you don't like the price for the engine rebuild he eats the cost of the tune-up but still charges for diagnosing the problem.
It's not his fault you don't want to go ahead with the repair.
So what I'm saying is that I would eat the cost of replacing the GFCI receptacle but would still charge for diagnosing the problem. If I can't figure out what the problem is I don't charge anything not even the dispatch fee.
