dmanda24
Scenario
-existing elevator machine room is being fitted with a sprinkler head
- There is a FACP in the premises
-heat sensor needed 24" from sprinkler to shut off power
-smoke detector esl 429crt is present in the machine room,not within 24" of sprinkler
questions
- does the new heat sensor have to be connected to the FACP
- smoke detector (429crt) is also a fixed rate heat detector, if I relocate it to be within 24" of the sprinkler head will that meet both the heat sensor and the smoke detector requirements.
- relays on the 429crt are being used to connect the unit as a 4 wire smoke detector, how can I connect the unit to to the shunt trip breaker?
questions
