electrofelon
- Cherry Valley NY, Seattle, WA
- Electrician
Yeah seriously, a bead of silicone then tighten, that would work 1000 times better than this gaskets and allow tight fittings. I might just start doing that. BTW I care very little about water entry, it's that the fittings can't be tightened and/or will become loose when the gasket gets ruined by the weather.A bit of RV silicone makes about any thing RT. The red stuff helps identify which ones you missed.
It's kind of ironic, with all the obsession about grounding and bonding in the industry, then you have these things which make for absolutely horrible ground fault path.
