Ravenvalor
- Triad region of NC
- Electrician
CFLs
CFLs
Thanks for the great replies. The instruction manual for the EJ500 timer states that it is not designed for cfl lamps or lamps with candelabra bases. This is exactly what is being operated by the EJ500, front yard column lights with a total of 6 - candelabra base cfl lamps. The lamps and the timer were installed about 6 - months ago (I wanted to experiment) and when I went there yesterday I noticed they were giving the customer trouble. If he continues to have trouble I will replace 2 - of the 6 - lamps with incandescent lamps. I do not have a meter more sophisticated than a standard multimeter and an analog clamp-on amp meter.
Gar - it is a 2 - wire timer (quote - "meaning it is in series with one lead to the load, then there is not enough current thru the load to power the timer"). I imagine those lamps probably are rated about 13 watts each. If 78 total watts is not enough then a couple of 60watt lamps should help.
Thank you,
Jim
CFLs
Thank you,
Jim
