I wish I could get the inspectors in my area to come to this site. Then again, I wish at least one or two of them would bother to read the code book once in a while also. This morning I was on the phone with one who is sending me back to a job because he wants me to add a ground rod to a service I just did. I had put in a CEE, and also ran a H2o electrode conductor. Both were #2 (I had #2 in truck, could have used #4). I tried to explain that the rod is not required by 2005 when you put in a CEE , but he informed me that it is, "now the code wants us to have all three". So then I reply (eyes rolled up) "ok, since the code wants us to, I will be happy to go back and add it. By the way is a single run of #6 over to the rod ok with you? Answer- " No, it has to be a #4 and it has to go to the water pipe first and then over to the rod.You can't run individual runs to ground electrodes. And also it has to be solid. Me again - " Is there some local amendment I never heard about that dictates all this stuff you are saying? If so I would love to get myself a copy of it in order to be able to comply with all these requirements that I never had to do before."
Answer- "Its all in the code, just do it like I am telling you to." End of conversation.
Edit - I left out some details, 200 amp service,#2 thhn/thwn copper gec's used. Another inspector was there before the pour and saw the CEE. I used a listed clamp. My H2O clamp (accesable above grade) was listed for direct burial also.
