agreed
agreed
my group wears 8 cal shirt and pants (hrc 2*) at all times as well as sfty shoes. hard hat with face shield and chin cup (15 cal) and balaclava to comply with notes 7 and 10, for hrc 2 and 2*. gloves, tools and meters @ 1000 vac.
we are working on specific instructions and training for repetitive tasks. That task requires an Intermediate Energy State with a LOTO with a sp disc. downstream from E-1, that removes elec. supply outside the panel. Voltage=120vac and IE is less than 1.2 cal. task is done daily to weekly. written instructions on the panel door. training cert. on file. no job briefing required.
this is for a honeywell flame control, with ignition relay and flame relay. have 36 in operation at any time with that many spares. 5 minutes to swap out. shouldn't require a job briefing every time.
by the way, our LO rules require E-1 (main) locked unless there are specific instructions for the task and a risk anaylsis is done, then instead of shutting down an entire printing press, we can shut off power to a particular panel on that press with a lock out switch external to the panel. hubbel has some rated as disconnects.
