110411-1247 EDT
First, some data from one of my freezers:
Just after the beginning of the of the cycle
Volts .... Watts
105 ....... 309
110 ....... 317
120 ....... 325
125 ....... 334
130 ....... 345
A few minutes later, but not yet at steady-state
Volts .... Watts
100 ....... 293
105 ....... 295
110 ....... 298
120 ....... 313
125 ....... 322
Note: 295/322 = 0.916, an 8% reduction.
This freezer runs about a 50% duty cycle. Thus, the energy consumption is about 0.150*8760 = 1314 KWH/year. My cost about 1314*0.132 = $174/year. If I reduced this by 10%, then the saving is $17/year.
Based upon what I believe the Smart Plug does and somewhat confirmed by talking to them I believe the device will save some energy. I would want their small device to be priced in the $25 to $50 range, but guess what its price is? $400. Knowing roughly what would be in the box it is way over priced.
On to the technical aspects. I would not call it a scam. The limited description is probably not too inaccurate. The description was not written by a electrical engineer in the United States. It might result by translation from a description by a foreign engineer. The PowerDEX company in Nevada is not likely where this was designed and being manufactured. Note: it is a west coast company so you can not call too early. The person I talked with has some knowledge about the product, is not an electrical engineer, and has some experimental experience with the product.
Their estimated saving is possible in some cases, but this needs to be considered in terms of the product cost and its relationship to the load to which it is connected.
They say it should not or can not be used with things that include electronics. It should be made perfectly clear that this device is designed to be used with a single induction motor. They describe it as using the peak of the sine wave. More likely it is a Triac or SCR with phase shift control to reduce the output voltage.
Clearly if applied to my freezer there would be no reasonable payback period.
They gave me an illustration of where there is a good payback time frame. A 1 HP pump motor for a pool that is run continuously. They also admit that they need to find those applications where the load device runs continuously, and the rating of the load is near the rating the Smart Plug. The load also probably needs to run near its rating, and there is a high supply voltage. They have real world data from the pump application that indicates a payback within about 3 years.
Without the device to play with I can not judge how the improvement varies with input voltage. My guess is that if the nominal voltage is around 110 V there won't be much improvement, whereas, at 125 V their percentages might work out. No way would I speed $400 to experiment with this device. At $50 I might.
I would not call this a scam, but rather a product with limited application at its current price.
