- Simi Valley, CA
Every ESD matting I installed had a sheet of copper under it and a ground rod attached to the copper. That makes it pretty well grounded in my opinion. Now things may have changed in the thirty years since I've installed any.Im sorry but I strongly disagree with everything that you said. Not at all true. You are no more conductive and nothing is going to suck electricity towards it. SDT just gives a path to earth for static discharge only caused by friction in a low humidity environment seperated from earth by an insulator typically on your feet. Would not even blow a breaker if you laid a live conductor on it.
