@greg I have installed nearly every major brand there is. At least one of them has failed at some point. Mostly software or component related I assume. The only catastrophic failures I have seen are due to installer error when installing the conductors. I don't think there is a real wrong choice to any of them of you just want one that feeds power to the car. In my world though, it is all about ease of install, material quality, customer support, looks and features.
We chose for non-Tesla the Chargepoint HomeFlex. It has the ability to set the max output up to 48 amps. This allows us to fit it into panels that may not have much available amperage as well as give up to 48 amps to panels that have room. It has a user friendly app that allows you to monitor car charging, remotely access for troubleshooting as well as change setting. It was around $700 but we got a deal from the supplier. It is easy to install( which is one of the most important things) and their customer service is good. I don't like that you can only enter from the bottom and back, but not a lot of chargers have the top entrance option. This maxes out at 48 amps on a 60 amp breaker. I don't recommend to anyone( including Ford and Lucid owners) to install anything bigger( like an 80-100 amp charger). Its not worth the added cost of the beefier charger or the possibility of needing a service upgrade due to the high draw. Most people are home 8-10 hours a night which is more than enough time to charge your car at 48 amps or less.
For Teslas, buy the Tesla Wall Connector. They even sell a J-1772 one that fits non EV's. Tesla's charger is on their 3 generation. Its far cheaper and far superior in all aspects to any other charger brand. You can adjust the output via Wifi and Tesla can remotely access for troubleshooting. It has integrated load sharing allowing you to install multiple chargers on the same circuit. This basically means if you only have 50 amps available you can install multiple chargers on the same feed and it wont overload that breaker. Lastly, we are part of their pilot program that allows you to add CT clamps to it to monitor your main breaker draw. If you get close to 80% of the main it will lower the output of the charger to avoid overloading the main. This is great for houses with 100 amp or less services. It also allows wiring from the top, bottom and back. They do break. I would say 1 in a 100 break but they are very easy to swap out. I would sell the J1772 ones more but non-Tesla EV owners get a little territorial and don't want to see the name Tesla near their Chevy Bolt.
I have not had any issues with Juicebox EnelX more than any other brand. I actually like them, they were the first to have a load share option.
The only other thing I would mention is that if you are installing a NEMA 14-50 ( range outlet) Don't cheap out. To me its not worth the risk. Google melted nema 14-50 if you don't believe me. In fact any plug in EV chargers should use the highest quality outlet you can find. 8-10 hrs of constant heat will expose residential/commercial grade outlets. Use the Hubbell ones that cost $80 to $100. They have never failed me and its worth the peace of mind.
Hope that helps
