kwired
Electron manager
- NE Nebraska
I guess with evaporated milk when you are done drilling holes you can add a little water and have some milk, most products marketed for cutting and drilling aren't recommended to ingest.
LMAO!!!Hmmm....I need to drill some stainless and am out of cutting oil, let's see what's in the cupboard....or I have a coolant leak in my '73 Impala, let's pour some black pepper in the radiator.
That actually works on small radiator leaks. I had a '67 Econoline I used that trick on and it worked very well. The only thing was that every time I removed the radiator cap it smelled like I was cooking a gumbo.I've often wondered where/how these "remedies" evolved? Hmmm ... I have a coolant leak in my '73 Impala, let's pour some black pepper in the radiator...
I don't know all the details of how/why, and do agree that most any oil may help but have seen especially for pipe threading that an oil intended for pipe threading is better then just any oil.Run your drill slow. I've used WD-40, PB Blaster, or cutting oil for threading pipe -it's kind of thick. Trans fluid. Basically any type of petroleum product.
The key is running the drill slow on low to get the torque.
Might try what I have seen mirror people use when drilling a hole in the mirror. They used duct-seal to form a little dam around the area & then put anti-freeze/coolant inside the dammed area. Coolant keeps the vehicle engine cooler, so worked on their application. And yes, low speed!
But in an engine it absorbs heat as it is pumped by and takes it to the radiator where it gives up heat as it is pumped through it - you constantly have coolant moving past the area you want to remove heat.Might try what I have seen mirror people use when drilling a hole in the mirror. They used duct-seal to form a little dam around the area & then put anti-freeze/coolant inside the dammed area. Coolant keeps the vehicle engine cooler, so worked on their application. And yes, low speed!
